1991 Corolla (4afe 1st generation) Need Bracket Function and Location
Over the past two months (only on sunny Mondays), I have worked on replacing the timing belt in my 1991 Corolla wagon. Today, I finished the task but have a bracket left over that I cannot remember where to place. The bracket is not the one for the motor mount. The unknown bracket is much more flimsy than the motor mount bracket and has a place for a bolt on one end, but the other end seems to hook into something. Can anybody help me identify this unknown bracket?
I would also suggest posting a picture but judging from what I can recall from my experinace with Toyota timing belt jobs I would guess it's the bracket that goes from your alternator to the water pump housing. May be a 14mm on the alternator slide it slides into and a stud that may stick out from your water pump which would be held down by a 12mm nut.
