Jumpy car and black smoke
Hi,
Fresh member from Norway.
I rarely have trouble with Toyotas, but thus 2006 Corolla is an exception. Manual shift, diesel, 165.000 km.
Symptoms:
Jumpy engine when driving. Idle is normal.
Black exhaust.
Error code (by professionals) indicating:
- Oxygen mass sensor failure
- Damaged intercooler. Also visually confirmed.
Both parts replaced with no improvement.
Diesel filtet replaced
- just to be sure
Other sources that is eliminated:
Turbo and all surrounding components
Hoses
EGR-valve
Air filter
I will be most grateful for any relevant suggestions from Corolla owners and/or mechanics.
Hello and Welcome
Your jumpy engine... check and make sure your engine mounts are not wore & tore.
oh.. also rotating your tires and readjust your PSi.
change out your pcv valve :confused:
