Any idea about this part's name? 96 Corolla Hatchback
Tieigo
Hello Folks, do you guys have any idea of what is this part is? It appears to be some sort of electronical air related thing that stays next to the 16 valve "thingy", Any clue?
Yea it looks like a Throttle Check Valve - Those usually don't go bad . Your probably looking to get one of those at a junk yard . Did someone tell you that part is no good ?
I would check for cracks in the hoses , Especially the PVC valve , If you have a mass air flow maybe needs to be cleaned . Distributor cap and rotor button can be going bad . Is there a way you can put up a video of the sound your hearing or feeling ?
I'm just saying those rarely go bad all it is , Is a valve suction one way not the other you can take that off and just suck on the end and blow to see if it is working . PVC valve should be rattling when you take that off if it is rattling slow or sticking that could do the same issues .
