Go Back   Toyota Corolla Forum > Corolla Tech > Toyota Corolla Maintenance
Reply
Old 05-27-2011, 05:07 PM   #1
EWyatt
Junior Member
Default Changing the Oil Filter -- 2011 Corolla 1.8 L
This may be an old subject, but new to me! I've read all the supposed horror stories about changing the filter element in the cannister-type oil filter assembly. Is it really that tough?? Do I simply need to buy a removal device to unscrew the filter cap, then simply remove and replace the element? Or are there some other devices I need, some other procedures to take. I haven't found any good web sites that deal with oil filter changes. Anyone, please comment. Thanks.
EWyatt is offline   Reply With Quote
Join Corolla Forum
Old 09-30-2011, 10:16 AM   #2
kyled
Junior Member
Default
It's the same as the 2010 Camry, so changing it will be the same. There are even videos on Youtube showing you the process, step by step, so go ahead and search there. Good luck!
kyled is offline   Reply With Quote
Old 11-21-2011, 11:35 AM   #3
Scott O'Kashan
Scott O'Kashan's Avatar
Default
Hello EWyatt.
The cartridge type oil filter isn't tough to change at all. I searched YouTube for you and below is the best video I could find on this topic. The 0W-20 synthetic oil is what Toyota recommends for your car. Whenever you change oil, be sure to wear rubber gloves as used oil is toxic and can cause cancer. I hope this helps answer your question.
http://www.youtube.com/watch?v=BSWn2SMrNfI
Scott O'Kashan is offline   Reply With Quote
Old 12-31-2011, 08:37 AM   #4
trlhiker
Member
Default
Quote:
If you bought this new, maintainance is free so why change it yourself?
trlhiker is offline   Reply With Quote
Old 01-01-2012, 12:34 PM   #5
Scott O'Kashan
Default
It could be they want the superior performance of a good synthetic oil.
__________________
http://www.HiTechOil.com
Independent AMSOIL Synthetic Lubricants Dealer. Send a P.M. for a quote lower than competing products. AMSOIL At Wholesale Prices 30-35% Lower Than Retail Why AMSOIL? Help Wanted - Become an AMSOIL Dealer for $15
Old 01-24-2012, 01:20 AM   #6
corolla_mike
Member
Default
Seriously, for the sake of your warranty, go ahead and have your oil changed at a reputable dealer/pro oil-change shop.
corolla_mike is offline   Reply With Quote
Old 01-27-2012, 12:34 PM   #7
Scott O'Kashan
Default
If the vehicles owner changes the oil, per federal law it doesn't affect the warranty of the vehicle one way or the other.
__________________
Old 02-29-2012, 06:21 PM   #8
kyled
Junior Member
Default
I used YouTube as well to change my 2012 Corolla's oil filter. Very easy, glad I did it myself. Took me about 20 minutes all together. Hardest part is screwing and unscrewing!
Old 10-01-2012, 07:08 PM   #9
Scott O'Kashan
Default
Quote:
It's a good idea to allow the old oil to drain out for at least an hour to get as much of the old oil, dirt, wear metals, water, fuel, etc., out of the engine as possible. This will help extend engine life. When I change oil in my own or customers vehicles, I let the oil drain out until it stops dripping. To aid in getting as much of the old oil out as possible, remove the oil fill cap and oil dipstick so air pressures can be equalized and the oil drains out faster.
__________________
Old 11-12-2013, 06:19 PM   #10
silvercorolla
Junior Member
Default
I am about to do an oil change on my 2011 Corolla with the 1.8L engine. Do I jack up the car from the frame behind the front tire, then put a jack stand under the frame? This is how I have always done it with my cars and this being a newer car, I just want to make sure I don't damage anything. Any help would be appreciated.
Thanks!!!!!
silvercorolla is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What Size Oil Filter Wrench? '10 Corolla Kev250R 2009 - 2013 Toyota Corolla 8 09-04-2014 10:02 AM
Changing the Blinks from 3 to 7? Donabed Kopoian 2014 - 2015 Toyota Corolla 4 03-14-2014 09:48 PM
Found a Little Problem While Changing Oil jwc1080 2003 - 2008 Toyota Corolla 2 06-22-2012 10:34 PM
2008 Corolla: Changing Rear Brake Shoes joseccz 2003 - 2008 Toyota Corolla 1 04-18-2012 02:44 PM
Engine Oil & Oil Filter Changing islam.1060 2009 - 2013 Toyota Corolla 4 04-02-2012 05:23 PM
