Go Back   Toyota Corolla Forum > Corolla Forums > 1998 - 2002 Toyota Corolla
Reply
Old 09-29-2013, 06:20 PM   #1
qwksti
Junior Member
Default Suspension Torque Specs
hi all
im replacing my mothers suspension on her 2000 corolla. does anyone have the torque specs for the 3 upper bolts and two main bolts? ive done some poking around and didn't see anyone post these numbers...
thanks
Patrick
qwksti is offline   Reply With Quote
Join Corolla Forum
Old 09-29-2013, 07:18 PM   #2
Scott O'Kashan
Scott O'Kashan's Avatar
Default
Hi and welcome aboard.
I don't have access to the information you request and just as a suggestion, I wouldn't recommend trusting such vitally critical information to an unknown source/stranger on the Internet who could provide the incorrect information and the dire consequences that it could mean.
Secondly, what do you mean by replacing the suspension? That would be an incredible amount of work and costs thousands of dollars, so I'm assuming you are referring to replacing the MacPherson struts?
__________________
http://www.HiTechOil.com
Independent AMSOIL Synthetic Lubricants Dealer. Send a P.M. for a quote lower than competing products. AMSOIL At Wholesale Prices 30-35% Lower Than Retail Why AMSOIL? Help Wanted - Become an AMSOIL Dealer for $15
Scott O'Kashan is offline   Reply With Quote
Old 09-29-2013, 07:24 PM   #3
qwksti
Junior Member
Default
im replacing both front and rear struts / shocks. not that big of a job. parts were $800 for the ready to install set up. just need the torque specs. autozone had them, top 3 nuts are 29ft lbs, and the bottom two bolts are 113 ft lbs.
Old 10-08-2013, 09:50 AM   #4
porschpow
Senior Member
Default
Sorry to hijack, but How hard is it to replace struts and whats involved? How can you tell if your struts are bad?
porschpow is offline   Reply With Quote
Old 10-09-2013, 10:32 AM   #5
qwksti
Junior Member
Default
Quote:
how to tell, the basic is, push down on the front and/or rear , the car should not be to easy to push down, and the suspension should not bounce. it should depress then come back up and stay. you could also be able to tell when driving the car will "float" over bumps and keep going up and down. plus ( in my case ) my mothers car was all original parts and it has 180,000 miles. so it needed it.
replacing it was pretty easy. i got the ready mount Gabriel suspension kit from auto zone. took me alone about 3 hours to do. and it only took me that long because the front bolts were on so tight and kind of rusty, that i had to work them some to break them lose.
only other issue was the rear. when removing the shock houseing the brake line mounts on the shock housing. the mount bracket for the line is not cut. meaning they want you to break the brake fluid line to remove it. but i just cut the tab and bent it so i could get the line in and off. then just bent it back. really no big deal. much easier than having to bleed the brakes.
other than that, pretty easy job.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Question On Power/Torque vs 2005 S gojoe 2014 - 2015 Toyota Corolla 11 08-15-2014 06:13 PM
Alternator Specs? j dubya 2014 - 2015 Toyota Corolla 8 08-13-2014 02:34 PM
Suspension dp12 2009 - 2013 Toyota Corolla 9 05-01-2014 07:38 PM
Need More Ideas for More Torque Taaz2389 2009 - 2013 Toyota Corolla 5 04-13-2014 10:54 AM
Torque Specs for a '94 Corolla? JRoseK 1993 - 1997 Toyota Corolla 4 06-04-2013 06:03 AM
