Go Back   Toyota Corolla Forum > Corolla Forums > 1998 - 2002 Toyota Corolla
Reply
Old 11-30-2012, 02:43 AM   #1
skinnnerj
Junior Member
Default 1998 Corolla - Oil Pressure Problems
I bought a 98 corolla awhile back. it runs good but i'm having real problems with the oil pressure, the engine had allot of gum build up in the pan so i removed the pan and cleaned it along the pick up tube. i also took the time to change the oil pump. When the car first starts it builds 90 psi of oil pressure (on and after market gauge i installed) after 10 mins of idling, until the car warms up the oil presume drops to nothing, the car does have 144k miles on it and im running 10w-40 in it. i was wondering if anyone has had or heard of the same problem. im thinking about rebuilding the lower end. Am i headed in the right direction?
skinnnerj is offline   Reply With Quote
Join Corolla Forum
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1991 Corolla - Oil Pressure Light On Amy Toyota Corolla Maintenance 7 09-03-2014 12:46 AM
VIDEO - Corolla Tire Pressure Monitoring System, (TPMS) Scott O'Kashan Toyota Corolla Maintenance 0 04-11-2014 06:26 AM
1998-1999 Toyota Corolla AE111 4A-FE Distributor Problems Hans 1998 - 2002 Toyota Corolla 1 12-21-2013 09:20 AM
2013 Corolla - Recommend Tire Air Pressure rajkumar.t08 2009 - 2013 Toyota Corolla 5 09-22-2013 01:44 AM
1998 Toyota With Electical Problems - Help ssheriff08 Older Model Toyota Corollas 2 07-25-2013 03:47 PM
