Go Back   Toyota Corolla Forum > Corolla Forums > 2009 - 2013 Toyota Corolla
Reply
Old 02-01-2013, 10:55 PM   #1
Sythos
Junior Member
Default 2011 Corolla - Why 35 PSI for Low Tire Pressure?
Greetings all,
I bought a Corolla S a couple of years ago and have all sorts of great things to say about it. Good gas mileage (as long as you don't load it down with 800 pounds of humans as I tried once), rides fairly smooth, quiet, decent acceleration .. and on and on. All that being said, one simple little thing is pushing me away from ever buying another Toyota.
EDIT - 2011 Corolla S - Stock with OEM tires.
Why did they set the low tire pressure monitor to such a high pressure?
The light started coming on within weeks of my purchase and when I first took it to the dealership they told me .. are you ready for this .. that every tire had to be at 35 PSI at cold temp. Now, I have seen a few posts on these forums and others where everyone tells people how to reset this, inflate that, and so on, but the REAL problem here is that 35 PSI is just ridiculous.
1) The door frame states 32 @ cold.
2) The OEM tires state right on them 'Inflate to a MAX of 32 PSI'
3) The owner's manual states 32 PSI max in multiple places.
So every time I take it to Toyota for the free oil change they inflate the tires to 35 PSI. Even though I knew I should not stand for that I let it go since the light does go off.
Here is the problem. I now have two OEM tires going flat on a near continual basis at only 15k miles. I took them both off today and did the old soapy water test. They are leaking major air around the valve stems. BIG SHOCK given that they have been over-inflated for two straight years.
Now, I know how to 'reset' the system, but will that allow me to set it to a more realistic 'number'. In other words, if I set them all to say .. 30 .. and then use the reset, does it actually 'relearn' to use that as the pressure to trigger the warning or does it simply reset the light?
I am interested because I am going to have to either get Toyota to replace these using 'Liability Language' or buy new tires myself. There is not a single light passenger tire on the market that I could find that does not state 32 PSI max, so I fear I will just keep having problems.
The light is a great tool when it is working correctly and setup correctly, but 35 PSI is just stupid. I have been told by two different tire dealerships that it is a known problem with Toyota across multiple models. The second dealership didn't even know I had a Toyota when I called, and they asked 'is it a Toyota?' Wow! He stated they do it to increase gas mileage. I know that over-inflating can help to increase gas mileage, but is an extra MPG or two worth ruining tires far before their time?
Sorry for the length of the post, but I am very frustrated with this as it is absolutely ruining my confidence in Toyota. If I don't get any good responses I will just go back to the old way by disabling that warning and keeping the tires at 32 PSI. I border on near OCD when it comes to checking my tires anyway so it would not be a big thing .. but I would really like my cars features to work correctly. More to the point, I want someone at Toyota to acknowledge that if every printed label and book says 32 PSI and the gauge is not set correctly.
I need help.
Thanks in advance to all who read this and any who have any ideas. 35 PSI is just .. wrong.
Sythos is offline   Reply With Quote
Join Corolla Forum
Old 02-02-2013, 01:32 AM   #2
Scott O'Kashan
Scott O'Kashan's Avatar
Default
What year is the Corolla?
__________________
http://www.HiTechOil.com
Independent AMSOIL Synthetic Lubricants Dealer. Send a P.M. for a quote lower than competing products. AMSOIL At Wholesale Prices 30-35% Lower Than Retail Why AMSOIL? Help Wanted - Become an AMSOIL Dealer for $15
Scott O'Kashan is offline   Reply With Quote
Old 02-02-2013, 01:36 AM   #3
Corolla Boy
Member
Default
I've a 03 corolla, I supposed u have a corolla S 2009+, not sure, but 32psi is too low for stock. Need more info about car/tires.
Corolla Boy is offline   Reply With Quote
Old 02-02-2013, 01:42 AM   #4
Corolla Boy
Member
Default
Or maybe low pressure monitor has problem...
Old 02-02-2013, 12:49 PM   #5
Sythos
Junior Member
Default
Thank you for the replies so far. Sorry for leaving out the year.
2011 Corolla S - Stock, still with OEM tires that specifically state 32 max PSI.
The part I don't get is why the tire, door jam, and manual all state 32 clearly, but on three trips to service department three different people and the service manager have told me 35 minimum for the monitor to clear. And I have tested it and they are right. It only shuts off at 35.
Was hoping there was a way to set it to 32 (or more realistically 30 since it should only come on when tires are low enough to be a concern). I would guess there is a way to do it with a computer change of some sort, but I was hoping there might be a way without spending a bunch of money.
Old 02-02-2013, 01:06 PM   #6
Scott O'Kashan
Default
What kind of tires are on the car and what size are they?
Is the size P205/55R-16 and is the tire the Goodyear Eagle RS-A, or the Bridgestone Turanza EL400-2?
__________________
Old 02-02-2013, 02:42 PM   #7
Ted
Member
Ted's Avatar
Default
I don't understand the problem and this business of clearing the monitor. You can set the tire monitor at any pressure you like. If you want 32 psi, put 32 in the tires, turn the ignition key to one of the on positions, hold the tire monitor button (under the dash) until the tire indicator light blinks 3 times, and you're all set. Now the indicator light will come on when a tire's pressure drops to an unsafe level.
__________________
2012 Corolla S
2006 Tundra
Ted is offline   Reply With Quote
Old 02-03-2013, 03:46 AM   #8
corolla_mike
Member
Default
Dunno, mate, but 35psi cold is ridiculous.
Matter of fact, just this morning I went out in 5F weather to find out why my low pressure light has been on. Max tire pressure for my set of Cooper Lifeliners is 40 psi. When I checked them with my brand-new gauge, left front and rear read 26 psi, right rear 20, and right front 24. So, figuring the indication was due to an imbalance of pressures, I pumped the low tires to 26 psi in really, really, really freezing weather. I mean, it was COOOOLD!!!
The light came on again at start, but knowing the temp was so cold, I reasoned that by the time the tires warmed up, so would their air pressure. And I've read that the indicator needed to be reset by pressing a button located somewhere either in the glove compartment or under the steering wheel. Didn't worry about that, though, and decided to take care of resetting the system when I returned home.
After only a few miles of driving, and to my surprise, the TPMS light went out on its own.
I say that if you diligently check your tires' air pressures, and find they are consistently at their proper level day after day, your troubles are with the car's monitoring system.
P.S. For all the attempts by various members from forums far and wide to accurately and with precision explain just where an indicator light reset switch is located, NONE has provided a picture of where it is. Couldn't find one anywhere I looked, but everyone says it's either in the glove compartment or under the steering wheel--SOMEWHERE. Good luck in finding your car's reset switch, if it exists at all. Sure couldn't locate mine. As it happened, I didn't need to find it.
corolla_mike is offline   Reply With Quote
Old 02-03-2013, 04:11 AM   #9
corolla_mike
Member
Default
Written data supercedes oral data all the time, every time. My advice: stick to what you read in print; the rest is hearsay.
Old 02-03-2013, 09:50 PM   #10
Sythos
Junior Member
Default
Ted, that is what I was asking. Does using that reset simply turn the switch off temporaril, aka reset it, or does that effectively reprogram it to use the current tire pressures as the new limit?
Seems I have gotten various answers from a couple of boards, so I just don't know.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tire Pressure newcorollaowner 2014 - 2015 Toyota Corolla 24 08-13-2014 11:34 AM
VIDEO - Corolla Tire Pressure Monitoring System, (TPMS) Scott O'Kashan Toyota Corolla Maintenance 0 04-11-2014 06:26 AM
2013 Corolla - Recommend Tire Air Pressure rajkumar.t08 2009 - 2013 Toyota Corolla 5 09-22-2013 01:44 AM
2010 S - Tire Pressure ShortyAnderson 2009 - 2013 Toyota Corolla 5 07-18-2013 09:57 AM
Tire Pressure Monitoring System Eastcoaster 2009 - 2013 Toyota Corolla 4 01-07-2013 02:22 PM
