02 EVAP Issue
Hey guys, getting P440 P441 and P446. The charcoal canister was replaced along with the valve assembly and still getting the same problem. When I run a smoke test from the service port, I get leakage out of the canister purge line.
The valves are new with the canister, is there anything else that can cause a constant leak from the purge port?
Does anyone have a shop manual that they can share or a diagram of the EVAP System? Maybe the hoses are not connected correctly?
Appreciate any insight.
If you live in an area where emission testing is not required, just ignore these CEL codes because they will eventually come back a year after fixing it.There are a couple youtube videos on the subject if you look carefully.
