09 Corolla Trunk Latch
Wondering if anybody is familiar with ‘09 Toyota Corolla’s wiring? I replaced my trunk latch with a motored unit and hooked it up to my aftermarket keyless entry system. I screwed up when I was testing it and it worked once, but the wires came undone while I was doing it and burned something out. I have checked all fuses and also replaced the latch as it wasn’t closing properly. I get voltage at the keyless entry but not at the latch, when I press the trunk open button.
Any advice in places to check or other forums would be greatly appreciated.
Thanks!
1) Does the keyless entry put out 12volts? If not you need to use a relay.
2) Try running wires from the battery to the trunk latch to make sure it still works. Remember you only need a momentary contact.
I have a relay which worked once. I replaced the latch, but although the relay is still putting out voltage, it isn’t getting back to the latch.
