09 Start Problem between a dead battery and crank. Please help
I was pulling into a driveway, and on the bump of street to parking lot, my car died. Now it only makes this sound. There's no grinding, and the serpentine belt is turning
My car isn't even making it to the crank. Here's what I've ruled out:
Replaced the starter
Replaced the alternator
Battery is about 6 months old
Have a crankshaft sensor, but since it's not even cranking I don't think that will work either.
I work the night shift so after this post I'm off to sleep, so any questions you have, I'll get to when I wake up
I would start by putting a full charge on the battery even though it is on the newer side. Also check all battery cables & make sure all connections are tight & corrosion free. Would be a good idea to check terminals on alternator and starter as well.
Thanks I will give it a try!
