My 1991 Toyota Corolla has an issue. The issue is that when the A/C compressor is engaged the idle speed drops really low and the condenser fan spins weak. What could cause this problem? Also I've noticed that when I floor my car while trying to enter the freeway, it doesn't go as fast as it should nonetheless the engine runs well as I had did a timing belt and tune up with Denso Iridium power spark plugs with .4mm electrode. What could cause these problems? Also should I replace my condenser fan since it spins weak?
