Hi there,
Recently I hit a deer in my car and it smashed my DS turn signal housing and bulb, as well as the DS headlight housing and bulb. I replaced the missing headlight bulb but have not yet replaced the turn signal.
For about a day, the headlights functioned normally - DRLs, hi/lo beam all worked. Then out of the blue the headlights stopped working. DRLs will run fine during daylight hours, but as soon as I try to switch on the headlights (hi or lo) they turn off completely. Also when it gets dark out the Twilight Sentinel turns off the DRLs and turns on the headlamps, which causes there to be no headlights again.
I have checked every fuse I could find as well as swapped the DRL and Headlight relays around to no avail. Note that I DO hear the headlight relay switching when I actuate the headlight switch in the car.
Can someone please point me in the right direction? I'm in bad shape not being able to drive after dark.
Thanks, Nilson
Thanks, Nilson
