So my mom has a 2001 Corolla and the parking lights are stuck on. I made sure the multifunction switch was in the off position and tried fiddling with the high beam function because the high beam indicator on the dash is lit up and the lights stay on no matter what. Also, it makes the "beeping" noise with the switch in the off position and the key out as if the switch was left on.
I thought it may be an issue with the DRL Relay so I pulled that out and checked it. I opened it up and the contact is not welded together, damaged or burned. In fact it's very clean and looks almost new. I started the car with the relay removed and it's still doing the same thing. My next thought was that it might be the DRL module under the glove box but I thought I'd try this forum before I start buying parts
I've read several threads mentioning a connector called the C203 (possibly C202?) where all the grounds come together. In the threads it said that this commonly melts and you lose the ground to certain components. When I Google it, I can't seem to find anything and I don't know where it's located so I can't even give it a visual inspection. Any thoughts? Bad Multifunction Switch? Bad DLR Module? Bad C203 connector? Any help/feedback would be greatly appreciated...
