2004 - Problem
Hello guys i have a problem in mi corolla s 2004 with 106000 millage , the problem is when i press the pedal o brake the car show a little vibration in the enginer and rpm down a little, i clean the injector , change the filter , spark, clear the tank of fuel , check the coil , check the ecu , and dont can solutione the problem , some people say , clear the valve iac but i need opinion about that, the car dont show the light the check engine , on is normally ..
thanx guys ... for help me
NOP, the symptoms of brake is diferent. the vibration feel in the enginer, and the rare is when i reset the ecu disconect the positive battery the vibration disappears, dont have the light check engine on.. thanx
Do you live in the U.S.? If so, you can get your Corolla's computer scanned for free to try and diagnose the problem. An engine running rough indicates a misfiring condition and this will show with a scan.
