2005 Corolla turn signal fuse
Does anybody have any suggestions on how to access the turn signal fuse in the fuse box under the left side of the dash? How about how to remove that plastic panel right in front of the driver's knees?
usually the flasher or turn signal fuses are in the engine compartment, right side when you open it up else under driver side dashboard. get in there, bend your sexy body, open your flash light, check the orientation, then hold the both sides of the cover, and you will feel there's tab that you can pull on one side, usually right one edge, pull it. if nothing on both sides, check the bottom edge of the cover, then read it. pull it too when putting it back on, is easier.
oh, if the fuse box is inside the pillar panel, you need to remove the door sill first, then pull the weather rubber strip, if the panel is secured with screw or plastic screw. then you will know if you can pull it up.
