I recently parked my vehicle for two weeks and during that time I started it up for a few minutes and it ran fine. There was no issue with the vehicle when it was parked and ran just fine. This morning I went out to start the vehicle and it will not start up. It's not very cold out here and the battery voltage is sitting between 12.3 and 13.0 volts. I have checked for codes multiple times with my OBD scanner and have not found anything. I also sprayed some starter fluid in the air intake and the car did not start after this which leads me to believe its not fuel related.
I have also checked for a clogged air filter and multiple fuses. Not sure where to go from here anybody have any ideas?
I have not checked spark plugs or coils yet because I thought that would throw a code if I had a bad one.
When cranking the vehicle sounds like it wants to start but also sounds off.
