2010 Corolla S Won't Start - Help
Hey Guys!
I have a 2010 Corolla S that is dead as a doornail! Zero power in the car. I tried jumping it and nothing. My headlights and dashboard light were flickering a little but, but I didn't get any warning lights before hand. It's the original battery from when I bought the car.
I bought it new in 2010 with 6 miles on it. It currently has 29k miles now.
The only reason why I ask is because I took it to the dealership for a recall to update the computer system. Is it possible that this could be a computer issue or is it most likely the battery?
Help!
Could be either. Get a $5 volt ohm meter and check battery voltage. If you have no charger you can charge with jumper cables from another car with the engine running.
HF
Ted
Just a quick note: when jumping with another car be sure that car is revving its motor in order to give you enough power to start.
