2012 Toyota Corolla Transmission Fluid Change
Anyone got a write up or know where I can find instruction on how to change the manual transmission fluid on a 2012 Toyota Corolla L manual transmission 1.8L. I've scoured the internet and I can only find stuff on the instructions for the older Corollas.
They are all pretty much the same. Loosen the fill bolt on the side of the transmission. The loosen the drain bolt. Put the drain bolt back on and fill until the gear oil flows out the fill hole. It takes 1.9 quarts and I recommend Redline MT-90 as it is great stuff.
You must have not looked very hard. I Googled it and found a bunch of information on it. Here is a video on You Tube. I change mine every 30k - 35k miles.
