2014 S rear brake pad DS uneven wear.
Hey everyone, having an issue with the rear driver side brake outer pad wear uneven. Original pads worn out at 80k so I changed to an aftermarket set of pads and new rotors. After 10 I heard brake squeal so upon checking out the pads found only the one side outer pad worn out on an angle, top to the metal, bottom almost 80%. Checked the slide pins and cleaned up then regreased, no issue there. However the pads fitted tight in the metal retainers/guides so I filed then down a little to let them move freely. After 5k they are still wearing unevenly. Can't seem to find the problem. Any ideas or experiences with this issue?
rear are disks like the front, the retainer m etal clip you changed out and greased as well? see if the caliper head is clean to.
