2014+ S Standalone or Independent Fog Lights?
Hello,
I've done this on my past IS300s, having the fog lights standalone and independent from the headlights. Should involve tie the fog relay to the ignition.
So you're able to turn your fog lights on whenever you want (when the ignition is engaged)
Has anyone done this or could help with the 2014+ Corolla S
Thank you.
Following, I'm looking to do the same on my 2018. I think you also have to tie into the high beam switch so the fogs go off with the high beam. State law I believe can't have all on at the same time. Mine is an LE so I don't have fogs now.
