2016 Corolla S - Fog lights and license plate lights
Hi... I was changing my bulbs to blue LED lights. Interior went well. As i was changing my license plate lights, auddenly they stopped working, turned off. I realized later that my fog lights are not working either. I played with the on switch numerous time no sign of them coming on... Any ideas on what could be the cause? Please help..
Where
The Obvious thing I can think of Is to see what happened is too check ur fuses first with everything off so won cause a short.
Thanks for your reply. How can i test them and where do i find them? Could it be a blown fuse maybe. Can ou please explain how i can achieve what you are suggesting.
Thank you very much
If i remember the fuse box for the fog lights is in the engine bay. It should be labeled there's also a little tool to help u remove the fuses. To see if they r blown is check if the lil wire inside is burn. The other fuse box is in the driver side under the dash.
