3 Reasons Why your Brake Lights Aren't Turning Off
#1. Worn-out brake pads
The brake pad is an automotive component that is subjected to extreme operating conditions. The brake pads are in charge of slowing down the car, whether it's on a slow or fast run. Brake pads will wear out with time, so you'll need to replace them to get a optimum braking power.
The electrical sensor wiring within your car's brake system would trigger your brake’s warning light located on the instrument cluster if a brake pad is worn out. You don't need to wait until your automobile makes a high-pitched or screeching noise before realizing the brake pads might be worn out.
#2. Low brake fluid
A sensor in the brake system determines the amount of brake fluid remaining in the main cylinder. The brake’s warning light will blink when the car’s brake fluid level in your car’s main cylinder dips to a certain level, indicating that it needs to be refilled.
Brake fluids can last about 2 years or 40,000 kilometers on average. Because brake fluids do not last as long as other automotive components, the brake’s warning light can commonly remain illuminated for an extended period.
#3. The parking brake has been activated
The brake warning light of your car's instrument cluster will illuminate automatically if you apply pressure on the parking brake. This means you won't have to disengage your parking brake prior to getting behind the wheel. Overheating will harm the majority of your car's braking components if you drive with the parking brake engaged.
#2. Low brake fluid
In case your car has been worn out, with the end of the year end sale coming, you can consider investing money in a new car.
