5w20 SB?
Took my car into take 5 to get the oil changed, guys at the shop told me 5 times they were adding 0w20 full synthetic.. added 5w20 synthetic blend oil anyways
Manual says 5w20 is ok, and I'm in florida so I'm not worried about cold starts.. but the synthetic blend part has me concerned, what should I do?
You should be fine. I would suggest changing it a lot sooner than the recommended 10K miles, when using full synthetic. I hope they didn't charge you for full synthetic.....
It was $65.. I gave them a $20 coupon at the end because I was worried if I mentioned it at the start they would throw in cheap oil. I ended up paying $43
It was supposed to be Castrol magntec 0w20 but it appears to be castrol hyperclean 5w20?
I usually do oil changes at 5000-7500 miles
