Bad Vibration
Hello,
I have a 96 Corolla DX and there is terrible vibrating from the motor. It is worse when the motor is cold for the obvious reasons but when it is in gear and idling after the motor is warm (at a red light for example) it still happens. The motor mounts were replaced and the problem is still going on.
Any insight?
Jer
Did you ever get your car fixed? It may be a dirty or bad fuel injector. Thats what t sounds like to me. When you step on the pedal you are forcing gas through it. But at a red light or idle, it struggle to get gas. Try a bottle of Sea Foam in the gas tank. Hope it helps.
JER
