Bought My First 2002 Corolla
Already having a problem and hope help is on the way.
Car has 108,000 miles on it. After changing the oil I decided to change the spark plugs. Problem I'm having is removing two of the ignition coils. Pulling up on them don't seem to help. I'm able to turn them (which makes me believe the plugs are loose). Any suggestion on how to remove them, even if it means braking them and replacing.
TIA for your assistance
Roger2002
Regarding the 2 coils that will not come off. There is a rail just above them that must be removed via a small screw. Remove the screw, move the rail over then remove your coils and plugs. I almost broke mine trying to get it out. Hope this assists.
