Coolant in oil not a head gasket
Discussion in '1993 - 1997 Toyota Corolla' started by Stuart15, Nov 17, 2017.
  1. Stuart15
    Stuart15 New Member
    Hi all a friend over heated the corolla and got coolant in the oil we thought it was a blown head gasket but changed the head gasket also had the head shaved but when we put it all back together and there is still a Lot! Of coolant in the oil can someone please help?
  2. Corolla Forum Sign Up!
  3. chris1261
    chris1261 New Member
    Cracked block or head?
  4. 3ddie @rana
    3ddie @rana New Member
    Did you send the Cly Head to get it checked out, Machine shop will give you a heads UP !
  5. beach bum
    beach bum New Member
    Do a compression check, and go from there. Could be a warped cylinder (s) , or like Chris said cracked block or head. New head gasket may have be installed wrong and torqued out of sequence.
Share This Page
