Crusie control work only when steering wheel is turned
Hi folks, on my 2011 corolla the cruise control light turns on only when I press the switch after turning the steering wheel left or right. After that if I try to set it I can't. I can't even turn off the light. For that I have to twist the steering again and press the switch. I tried putting in a new switch but same problem exists. Any help would be appreciated
I was guessing the same. But usually, people with clock spring problem report horn not working. my horn is working fine. but I think it is clock spring too. Will go ahead and change it soon. Thanks @ZeCorolla
