Ecu-ig no.2
This fuse keeps blowing when you turn ignition on had some wire repair on passenger side due to tire blow out repaired speed sensor wires and washer motor wires and a few ground wires but Don't know why the ecu-ig no.2 keeps going out?
Its possible that its not properly grounded. It could also be mistakenly tied into another wire that has a different amount of amps flowing through it, causing the fuse to blow.
