Exhaust or intake noise
Hi, new to the forum and Corollas as well!
I recently acquired a 2007 Corolla with a blown engine, Instaled a low mile used engine and runs great except when I put in gear and hit the throttle there’s a weird noise like an exhaust leak or intake leak only for a second when the motor is loaded up then goes away.. The exhaust manifold was cracked but welded up and new gaskets on both ends..
any suggestions would be appreciated! Thanks
Replace the exhaust manifold. Be careful not to strip the up stream o2 sensor and use new OEM header gasket and donut gasket. DON'T you liquid or gasket maker
