Fog light help
Gamma
I haven't bought anything yet until I'm sure of what I need, I've seen that people say that the things needed are the switch and relay
You can probably purchase the oem switch and change it out. Mine came with fogs so all I had to do was replace them with the led's.
I have the lights from the links above.
No problems and it took about 10 minutes to install them.
If it's pre wired, then you will only need lights, bezels and the oem switch. (it's part of the turn signal lever).
Otherwise you would need the whole kit and you would need their switch and relay.
There are other kits at lower prices, I've seen as low as $49.
I only suggested these because of their quality.
Anyways, I just did a quick search for the oem lever but haven't found anything yet. If I knew the part number it would be easier.
Gamma
Okey thanks for the info, my idea is to use a separated switch to turn on/off the fog lights so I think I have to do some adjustment to the pre wires under the dashboard, I was looking for that kind of diagram or tutorial
