I had passenger side clunk driving you could feel vibrations at high speed. Was inner tie rod and wheel bearing. Brakes plus did it in a day for 540 dollars. Car is now smooth. If you are wanting to fix it your self maybe take it for estimate maybe get oil change or something so your not just getting a freebe. Then after you do the work pay them for alignment. They took me in the back i got under the car they showed me it was obvious. Most suspension parts show ware. The driver wheel did have slop in it due to tie rod and bearing. Bearings are expensive on these due to pressing them out of knuckle. If you are on a real budget maybe go to pull and pay and pick a car that looks like it has a good bearing and buy the knuckle and bearing could save but remember its a gamble buying used. You will need a press to get the bearing out period. Thats front ones. Rear unbolt. Hope this helps. The noise was a shunk shunk rotating noise best i can describe
