Heat Issues
I just bought a one owner 2008 Corolla. Great little car but I'm having issues with the heat. Only warm air when the fan is on low of off. I changed the cabin filter, flushed the heater core, flushed the coolant (3 times) and replaced the thermostat. I burped it with the front end jacked up for 30 minutes or so. The only thing left is the water pump. Thoughts?
Thanks for reply. It has never gone past half on the gauge. I cant get it to overheat. What can go bad on a heater core? It passes water and was clean when I flushed it.
If heater core is ok it could be your thermostat is to low a temp. Check with parts place that you get parts from and see if they have a higher temp thermostat. Thermostats are set to open at a set temp. If it opens to soon your car won't get as hot as it should. You may have gotten the wrong thermostat.
