2016 corolla does not put out good hot air enough to drive in winter.
coolant temp is approximately normal as in using an IR therm to check heater hose temp is 175 F on the upper hose and 155 on the lower
if you set the hvac to 85 it warm in the center 2 vents only and as long as the fan is not on the 2 highest settings you put it on high and it goes cold
when looking at the actuators they are moving and not acting abnormal at all. i located 3 that you can see thru with the glove box removed 2 more in the center and 1 far right side. what else can i check or do to try to get this fix?
