Help car wont start
Hello i have been having a problem with my 04 corolla. Car will crank but not start. I tried removing the alarm but still wont start. Engine will turn to start but no ignition. This has happened a few time and some times i fixed it by removing an reinstalling a relay. But i replaced it this time and still wont start. What should i look for? I had a friend come by and he says its either the crank sensor or ecm. Not sure tho. Any help on this is appreciated.
Looks like you said you replaced that relay on the positive battery terminal. I would check it with a tester to make sure it’s still getting power past that relay. This has happened to me before and it was that relay rusted out
I take that back. Mine wouldn’t crank at all when I had that issue. That’s a tough call. Did you do anything to that car before this problem or was it doing anything to warn you?
