HELP! No A/C :(
Hi everyone, I have a 2009 toyota corolla le 2zr-fe. My ac is not blowing cold at all when placed on cold setting only room temperature air. I bought some refrigerant and hooked it up to the Low pressure side, but reading was literally at 0, so I added some, but it wont go past 22psi no matter how much I add. I realize I have a clutchless compressor, so on techstream I did a magnetic clutch active test, but I felt no difference turning it off and on. I know i should check the relays and fuses for the A/C but i spent like 2 hours searching the internet and there is no definite answer/location on where it is, idk if it'll make a difference or help, but the readings from the A/C live system on techstream read:
Ambient Temp Sensor: 83.93 F
Adjusted Ambient Temp: 81.97 F
Evaporator Fin Thermistor: 93.20 F
Engine coolant temp: 189.95 F
Regulator pressure sensor: 115.08 psi
Regulator control current: 0.856 A
Number of trouble codes: 0
Any help will be GREATLY appreciated, I need my A/C in this florida heat :(
