how do I remove the radio in my 2015 corolla L?
I don't know if the L is the same as the LE I have but all I did was pull the trim that goes around the radio that's between the steering wheel and passenger side door and four 10mm bolts to pull out the factory radio.
I have a 2015 with etune as well and want to do the same, pull my radio to add xm radio. Where does the trim start? was it easy to take out?
JoshTRD
its easy to take out once you first take it out...when you first remove it it is very stiff.....all i used to remove it all is a prying tool, thats all you need....
