Following are the new V10.10.018 Toyota Techstream software free download and step-by-step instruction guide provided. ToyotaTIS Techstream V10.10.018 software can be free downloaded here:
http://down.obdtoolshop.co.uk/toyota-techstream-10.10.018.zip
O/S: Windows XP without any anti-virus software
Techstream cable:
MINI VCI 16-pin cable, MINI VCI 16-pin and 22-pin cable, Xhorse MVCIcable
How to install MINI VCI Toyota TIS Techstream 10.10.018?
1) Install Toyota Techstream-10.10.018.setup
Open and run MINI VCI 10.10.018 setup
Select Language, click “Next”
Install software wizard, click “Next”
Accept license agreement, click “Next”
Click “Next” in Customer Identification program
Click “Install” when “Ready to install the Program” message prompts
Install Wizard is completed, press “Finish”
2)Activate Toyota TIS Techstream
Go to C
rogram FilesToyota DiagnosticsTechstreamEnvIT3System.ini
Change
TISFunction=1 to
TISFunction=0
Click Ok
Save
3) Install MVCI Driver 2.0.1
Open “MVCI Driver folder”
Install “Mini-VCI Driver for TOYOTA-CABLE 2.0.1”
Click “Next” then “Install”
Click “Finish” when driver is installed.
4)Com port setting
Open “My computer”>> “Device Manager” >> “USB Serial PORT (COM4)”
Make sure COM port is set to COM4
5) Run MVCI firmware update tool
Open “MVCI Firmware Update Tool” on the desktop
Click on “Device info” button to check device information, SN, firmware version etc
6) Configure Techstream 10.10.018
Open “Techstream” software on the desktop
Click “NO” to ignore pop-up Java message
Click “Setup” Tab>> “Tecshtream Configuration”
Select “Europe” in Area Selection windows, click “Next”
Select Tecshtream software language: English, click “Next”
7) Connect MINI VCI cable
Plug the Xhorse MINI VCI cable into the Toyota diagnostic socket
Click “Connect to Vehicle” in main menu
Initializing USB communication
After good communication is built, complete your vehicle information
Select system and carry out diagnostic function
Techstream cable:
Go to C
Change
TISFunction=1 to
TISFunction=0
Click Ok
Save
4)Com port setting
