Intake recommendations?
Hi guys, I was wondering what Intake would you guys recommend for the ones who own one , I am looking into buying one for my 16 Corolla but I am not to sure which one would be best . Let me know. -Thanks :D
I'm not sure how friendly an aftermarket air intake will be for your Corolla or headaches it will cause. These air intake doesn't do anything for these NEWER computer driven cars these days...
This all depends on what type of intake you choose. I have had both short ram and cold air, there's a huge difference between the two.
The cold air reduces your low end torque but increases your high end.
The short ram increases your low end torque but decreases your high end.
This is not as dramatic if you install a MAFS from http://www.jetchip.com
Which ever you install, you WILL notice better throttle response.
Also, aftermarket exhaust helps a lot too. Once your getting higher volume of air to the engine, you need to be able to exhaust it. TRD, Borla, etc.
Overall, with all of this installed, you might gain 5-8 horsepower. And you will probably see improvements in your gas mileage.
So for just under $1000.00, you too can be frustrated with the results! Lol!
