Looking to Add a Sub
I have a 2014 s,basic touch screen system, no nav xm or Internet. . Was wondering if there is any rca outputs on it before I start ripping it apart. If not I was going to add rca outputs to the rear deck. Also looking for a good spot to drill a hole through the fire wall for a 1/0 cable. Any info would be helpful.
found a spot to try drillingv but may need a longer bit
I'm a certified car electronics installer.
To answer your question, no the stock deck is not going to have RCA's in the back. I haven't ever pulled it, but I know for a fact that it wont. Also, don't waste your time adding a line-output converter behind the dash. Just tag off of the two rear speakers in the rear deck. Do so from the trunk and either run speaker wire from each speaker to the hi-level input of your amp or you can add in a line-output converter as you would have done behind the dash anyways. The less you have to take apart, the better.
