No factory caster or toe adjustment?
Got a 2014 LE that I have a lifetime alignment package through Firestone and 80,000 mile warrantied tires. I take it in for an alignment every 5k miles after my tires have been rotated, the front left wheel is no longer within spec for caster at 2.1 degrees and my right rear tire is commonly out for toe at about .09 degrees. The service adviser claims there is no factory adjustment for either. Has anyone else had issues relating to not being able to properly align their corolla and know of certain aftermarket arms or bolts that might be worth looking into? Car has not been in any accidents and is bone stock with 70k miles on it. Pretty frustrating that it already cannot hold an alignment.
Don’t worry about caster, it won’t wear your tires. Just as long as its close to the other side, it should be fine. The rear toe can be adjusted with shims and is a pain in the ass. You may even need a new wheel bearing when putting the shim in.
