The plug that leads out of the ECU (To the upper bank 02 sensor is delivering 9 volts of power). When I keep the multimeter positive probe on the plug hot wire and place the negative multimeter probe on the engine block I get 12.5 volts; Which leads me to believe that there is a grounding issue inthe 02 sensor wire harnass (In the car) itself. 2009 Corrolla LE 1.8L. Thus the new 02 sensor will not operate properly and I get code P0031. There has to be an easy fix for this but I cant figure it out... Other code I see is C1241. Please Advise.
