OEM Wheel Question
if the lug nut bolt pattern matches then yes.. i have 07 Corolla S and also a 10 Corolla S and the bolt patter are both 5x100 so i change them around from time to time
MikeW
My GF's Daily
All Corollas, 03+, have a 5x100 bolt pattern, a 12mmx1.5 lug size and a center Bore of 54.1.
Toyota wheels that will fit?
83-91 Camry (New ones are 5x114.3)
86-05 Celica
91-97 Corona
03-08 Matrix
04-08 Prius
Now the offset of the 09+ Corolla wheels differs from base to S to XRS. They're all in the +30 to +39 range. The above wheels, among others, might fit the lugs but the offset needs to be proper, or spaced to be made proper.
Wheel spacers can be very dangerous, increasing loads on the studs, which can cause them to snap. The result is a wheel flying off, which can really ruin someone's day.
Yes you can if the lug pattern is right as mentioned above.
Do not go 14" wheels whatsoever! I did the mistake of not seeing if the front caliper will clear, and it didn't when I paid for the damn steelies just so that I can mount and put on my 14" Winter tires. It's a waste of $60.00 for all four steelies. The back fits ok, but not the front.
Good luck!
