Parking lights stuck on
Discussion in '1998 - 2002 Toyota Corolla' started by Indiana324, Jul 23, 2018.
  1. Indiana324
    Indiana324 New Member
    hello,
    I have tried the driving lights module but it didnt fix problem, i was thinking of replacing the switch on colum but when i unplug it the lights still stay on, any idea what i could try?
    Parking light in front and back stay on
    Thanks
    Mike
  2. Corolla Forum Sign Up!
  3. OP
    Indiana324
    ok now ive tried two main relays backside of fuse box as well as headlight relay in engine area fuse box and also multifunction switch on column and nothing has worked....any ideas???
    thanks for any input!
    mike
  4. OP
    Indiana324
    nodody has a solution? now the high beam light is blinking off and on...what a pile these Toyota cars are!!!
  5. JohnnieXSE
    JohnnieXSE New Member
    Toyotas are pretty reliable. But if your car is over 15 years old, problems come up. If no one else can help with your electrical problem, try brining it to the dealer.
  6. Douglas Joachim
    Douglas Joachim New Member
    Did you check the switch underneath the breake peddal?
Share This Page
