Power Steering Pulley Removal.
Sounds simple but not when the pulley loosened up and now has no splines. So, how do I remove the pulley from the pump without any means of holding the shaft while undoing the nut?
Did you ever find a solution. I'm currently trying to take a power steering pulley off a 99 Corolla. Can't seem to figure it out. May end up taking pump off with the pulley just to remove the pulley.
