Rim Size Fitment
Discussion in '2014 + Toyota Corolla' started by Kevin Vargas, Mar 1, 2018.
  1. Kevin Vargas
    Kevin Vargas New Member
    Im looking at buying rims for my ‘15 Rolla S
    17”x7.5” Diameter, +38 Offset, 5x100 Bolt Pattern with 225/45ZR17 W tires from CarID, i’ve never bought rims from this site and just wanted to make sure they would fit
  2. Corolla Forum Sign Up!
  3. Chris Denton
    Chris Denton New Member
    Go to website http://www.willtheyfit.com
    I have no problems running 18x8.5 35mm offset with 225/45/18 tires. Plenty of room to go bigger!
  4. SuperchargedMR2
    SuperchargedMR2 New Member
    Those will fit just fine and the tire size is the best diameter fit. You are even okay with any wheel that is 8" wide and a 35mm offset.
  5. SuperchargedMR2
    Actually a 225/45R18 tire is too big. You should be using a 225/40R18 for the proper diameter that will keep your speedometer accurate. The proper diameter for the Corolla his 25.0" and the 225/45R18 is 26.0" which is way too big.
  6. Chris Denton
    I did the plus +2/-2 method and this is what it gave me. They are too tall though, I agree.
  7. SuperchargedMR2
    Well you calculated something wrong. I'm surprised that the tire shop you used didn't catch it. Here are the correct diameter sizes for our Corolla.
    195/65R15
    205/55R16
    205/50R17
    225/45R17
    245/40R17
    225/40R18
    215/35R19
    Any of these tire sizes are at the 25" diameter.
  8. Chris Denton
    I had the
    205/55/R16 and went to
    225/45R18
    +2/-2
    Lol, I purchased the tires online and had them shipped to the tire shop. Then I brought the wheels in boxes to them.
    They looked awesome at first, but now they definitely look too tall. I’m also kinda tired of the rims too.
  9. SuperchargedMR2
    It doesn't work like that as you think +2/-2 in sizes. As you you can see from the sizes I listed that are a perfect diameter. You were close but the difference between a 40 series and 45 series tire is very large in this case. You would be better off in swapping out the tires for the proper size. If you don't like the wheels you could just sell the set and buy new wheels that you like and put the proper 225/40R18 tires.
    Chris Denton likes this.
  10. svaldez1096
    svaldez1096 New Member
    Hey I'm new to the corolla scene and was trying to figure out what size wheels and tires to buy and wow this chart is really helpful, do you mind telling me where you found it or where it comes from ? I'm still trying to figure out what I want, I know I want 18s, but I'm struggling on choosing a set of wheels because I'm not too familiar with the sizing.
  11. SuperchargedMR2
    I've been around cars and used to sell tires and wheels many years ago so I just did it myself to help out others. The proper tire size for 18" wheels is a 225/40R18. Wheels come is different widths but a good fit for that tire would be a 18x8 +35mm offset. This will fill the wheel well nicely and look great. If the car is lowered you could lower it a little using some Eibach springs which will look even better and handle better while providing an excellent ride.
  12. JohnnieXSE
    JohnnieXSE New Member
    My OEM set up is 215/45R17, and it's not in your list
  13. SuperchargedMR2
    That's because it's too small of a diameter. I have no clue why Toyota uses the 215/45R17 size with a 24.6" diameter on the sedan when every other tire they use has a diameter of 25". On the Corolla iM hatchback they use the correct 225/45R17 size. Most people upgrade to a 225/45R17 when they shop for new tires. I also run the 225/45R17 on my 09 Corolla S.
    JohnnieXSE likes this.
  14. _scott_land
    _scott_land New Member
    You guys are awesome, I was just having a debate about this and you made me purchase a setup that I really like. Thank you guys sooo much.
  15. SuperchargedMR2
    Hopefully you didn't make the same mistake that he did and get the 225/45R18 size that is too large of a diameter. Go off of the list I left and you will always have the proper diameter in any wheel size.
  16. _scott_land
    What if your just running stock suspension and you run the 18x8.5 +35 with 225/40R18, will they rub?
  17. Chris Denton
    Never gonna let me live that down ehh? Hahahaha
    I gotta wear out what I have before I buy new ones.
    BTW, I want to go wider, like 245/??/18
  18. SuperchargedMR2
    No, they won't rub in any way but they will look better if you do a mild drop on Eibach springs.
  19. SuperchargedMR2
    I wasn't sure what size he was asking about since he used your quote. I responded because he referenced it. I wasn't picking on you! haha:rolleyes: If you want to go wider a 255/35R18 has the proper 25" diameter. :cool:
  20. _scott_land
    No worries I will drop them after since I don’t want to have to readjust if I lower with the stock rims
  21. Matt Comisso
    Matt Comisso New Member
    I have 18X9.5 all the way around on lowering springs and still enough room for when I go on bags!
Share This Page
