Sport Button problem - corolla 2015 S
Discussion in '2014 + Toyota Corolla' started by mustafa, Oct 12, 2017.
  1. mustafa
    mustafa New Member
    Hello friends
    as i adviced previously to change my gear box sport button , i carried on but still it dosent work
    i brought another sport button its not working.
    what now?
  2. Corolla Forum Sign Up!
  3. OP
    mustafa
    mustafa New Member
    guys i strongly need your suggestion please help me
  4. JoshTRD
    JoshTRD New Member
    I'm by no means an electrical man...thats what it sounds like....nothing you can really do man.
  5. Chris Denton
    Chris Denton New Member
    Sport button problem...
    Due to the location of the sport button, it is subject to liquids spilling into it. Has this happened? You can easily remove it and carefully disassemble it for cleaning. I would suggest rubbing alcohol and Q-tips.
    You may also purchase a new switch from your Toyota dealership.
    This may be all that’s wrong.
    I had a similar issues with my Highlander rear climate controls. The kids had spilt so much stuff on it that we had no control. After removing and disassembling it, I discovered that the dried liquids had made permanent connections between some of the contacts. Used some rubbing alcohol and Q-tips to clean it up. Reinstalled, and everything works like new again.
  6. OP
    mustafa
    mustafa New Member
    well , thank you chris
    i bought another Sport button but still it doesent works , despite i cleaned both button and its wire connector but still its quit.
    What should i do now ?
  7. Chris Denton
    Any way you can make a video of what your experiencing?
  8. OP
    mustafa
    mustafa New Member
    sure
    i will attach it soon
  9. Chris Denton
    Yeah, it would help a lot.
    I had another thought, maybe you have a bad coil pack or spark plug?
    Is your check engine light on?
    Do you have a code reader?
  10. qmantran
    qmantran New Member
    A corolla doesn't deserve a sport button
    :D
    Chris Denton likes this.
  11. Chris Denton
    More like it’s desperately needs one!
  12. 3ddie @rana
    3ddie @rana New Member
    Good Morning
    SAY NO 2 ALUMINUN LUGS, its a learning experience 4 me, learn from it the HARD way !
    JoshTRD likes this.
  13. OP
    mustafa
    mustafa New Member
  14. OP
    mustafa
    mustafa New Member
    hey buddy
    i tried to upload the video but i coudn’t
    kindly give me ur email add so that i email u
    or watssup and viber
    tnx
  15. JoshTRD
    JoshTRD New Member
    this may be wrong but i had a stroke of genius...... good it be possibly a blown fuse in your fuse box? if the sport button posses a fuse than i bet that is 100% your answer..... my headlight and taillight fuses blown and no matter what bulb i tried it did not work....ended up needing to change some blown fusses in the fuse box...
  16. OP
    mustafa
    mustafa New Member
    Thank you
    will try it tomorrow
  17. Chris Denton
    If you have a YouTube account you can upload it there and then share the link with us.
  18. 3ddie @rana
    share the link !
Share This Page
