Hydrogen creates environmental problems to. There is no free lunch.
http://en.wikipedia.org/wiki/Hydrogen_fuel
Hydrogen fuel is a zero-emission
fuel which uses
electrochemical cells, or
combustion in internal engines, to power vehicles and electric devices. It is also used in the propulsion of spacecraft and can potentially be mass-produced and commercialized for passenger vehicles and aircraft.
Hydrogen is the first element on the periodic table, making it the lightest element on earth. Since hydrogen gas is so light, it rises in the atmosphere and is therefore rarely found in its pure form, H2.
[1] In a flame of pure hydrogen gas, burning in air, the
hydrogen (H2) reacts with
oxygen (O2) to form
water (H2O) and releases heat. Other than water, hydrogen combustion may yield small amounts of
nitrogen oxides.
Combustion heat enables hydrogen to act as a fuel. Nevertheless, hydrogen is an energy carrier, like electricity, not an energy resource.
[2] Energy firms must first produce the hydrogen gas, and that production induces environmental impacts.
[3] Hydrogen production always requires more energy than can be retrieved from the gas as a fuel later on.
[3] This is a limitation of the physical law of the
conservation of energy.
Because pure hydrogen does not occur naturally, it takes energy to manufacture it. There are different ways to manufacture it, such as,
electrolysis and
steam-methane reforming process. In electrolysis, electricity is run through water to separate the hydrogen and oxygen atoms. This method can be used by using wind, solar, geothermal, hydro, fossil fuels, biomass, and many other resources.
[2] The non-polluting methods of making electricity (wind, solar, hydro, geothermal, biomass), rather than fossil fuels, would be better used as to continue the environment-friendly process of the fuel. Obtaining hydrogen from this process is being studied as a viable way to produce it domestically at a low cost. Steam-methane reforming process extracts the hydrogen from methane. However, this reaction causes a side production of carbon dioxide and carbon monoxide which are greenhouse gases and contribute to global warming.
[1] Even so, the current leading technology for producing hydrogen in large quantities is steam reforming of methane gas (CH4).
[4]
