X xarneco New Member Mar 22, 2014 #1 Mar 22, 2014 #1 Switch my 15-6" OEM rims to 15-6.5" with same tires, can I use same TMPS sensor, in my 2014 Toyota Corolla LE-ECO?
Donabed Kopoian 6 Speed Master Mar 22, 2014 #2 Mar 22, 2014 #2 The wheels need to be compatible with Toyota TPMS. If they are, you're fine. Why going to a slightly wider wheel if you are keeping the tires the same?
Scott O'Kashan Super Moderator Mar 22, 2014 #3 Mar 22, 2014 #3 Using wheels that are too wide can cause the edges of the tires to wear out prematurely. -- B.F.Goodrich T/A Certified Tire Specialist
