Trac and VSC
When I start the car, the display shows that Trac and Vsc is OFF, is this correct ?? Do I have to activate Trac and Vsc manually ?? If so, how do I perform this task ??
jolly
No, it is suppose to be on automatically.
Even when off, it is suppose to reengage under certain conditions.
Its either just checking the light (like all other cluster lights). Does the "off" shut itself after a few seconds ? Otherwise, it might be some defect.
ZeCorolla
I Love Corolla's!
Well, if you press the button to off it once, then it will re-engage after a certain speed but if you hold the button down for a few seconds, then both TRAC and VSC will stay dis-engaged until you press the button again or restart the car. As for starting up the car, the lights will stay on at the start so that the system can check to see if they are working and then the lights will go away. If it stays on, it could be a glitch with the light or there is a problem with the TRAC and VSC so you should go to a dealership for them to check what happened if the lights don't go away itself.
