Transmission CNC Help needed
Who can design transmission cooler port plate to screw on instead of water cooler, just have it cool normally without the water with trans cooler mounted in the front.
Also, do drop the pan and lay as many thin magnets in the pan to keep all the fine metal dust and flakes out of valve body, torque converter and few other component items.
In the CVT do make sure to make a complete stop before switching direction drive as this can cause uneven belt wear following belt vibration.
Then change trans fluid at around 75-90K miles
